2005 Vauxhall Corsa engine problem
BROXI09
Engine Mechanical problem
2005 Vauxhall Corsa 4 cyl Manual 28230 miles
i have a 1.2sxi 55plate corsa it have been driving fine till yestarday when my engine management light appeared and my engine started to go very sluggish and produced misfiring sounds and rattling is in the garage today and just had a new coil fitted however the dia comp has said there is a problem with the 4th cylinder as its still banging and running badly any ideas?
Mar 3, 2009 at 11:39 PM
DAVE H
  • 13,383 POSTS
first check the lead for #4 plug and the plug .. ask them to check and clean the CKP(crankshaft position sensor)and wires to it .. next to check is the injector and wires to it !! let me know
Mar 4, 2009 at 1:01 AM
BROXI09
hi thanks for your reply it was a broken camshaft the thing is i have found over 200 people that has had the same problem with the same make,model ect and all say same as the mechanic that looked at mine manufacture fault now need to find out what to do about it just hope its not caused any major damage
Mar 4, 2009 at 5:02 AM
DAVE H
  • 13,383 POSTS
I have been in the business 20 years and this is only the third time I have heard of this, will look a little deeper and see if there is any TSB's regarding this and let you know !!
Mar 4, 2009 at 8:03 AM
BROXI09
thank that would be great
Mar 5, 2009 at 7:11 AM
