pedal goes to the floor they tell me my master cylinder is bad
2004 VAUXHALL CORSA
39,000 MILES • 4 CYL • FWD • MANUAL
SIMWEB
The brakes on my car i have just discovered are not working properly. When i first press the brake pedal, brakes work ok, the next time i use it after that, the pedal goes to the floor they tell me my master cylinder is bad can you help me change it please?
Jun 26, 2009 at 10:13 AM
BORIS K
  • 836 POSTS
If you press your brake pedal while standing still does it also go down to the floor? If not then I would suggest to have a look at your wheel bearings, ensure that the is no excessive play. A bad wheel bearing can cause a soft brake pedal as it can cause the brake disc to open up the brake calliper when going around bends. A link how to is below.
https://youtu.be/YvKWGjmPKoc
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
If you find nothing wrong with the wheel bearings then I would suggest to first bleed the braking system. Air in the hydraulic system can cause the brake pedal to be spongy. A how to instruction is below.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
If you still require to replace the brake master cylinder then please follow the general description below.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Please let us know how you get along.
Cheers, Boris
Apr 6, 2021 at 2:18 AM
