2004 Vauxhall Corsa Are oil temp sensors better than coolan
2004 VAUXHALL CORSA
ALED_G
Engine Cooling problem
2004 Vauxhall Corsa 4 cyl Front Wheel Drive
Just wondered why oil temperature sensors are more accurate in determining the correct engine temperature for fuel calculations as opposed to an NTC2 coolant temp sensor, is it because its not water cooled? cheers
Apr 25, 2009 at 3:03 AM
DAVE H
  • 13,384 POSTS
Most engines are water cooled ... the OIL hold's a steady temperature evenly .. the water temp is constantly changeing ... hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_571.png
Apr 25, 2009 at 11:20 PM
