2003 Vauxhall Corsa Oil Burning
2003 VAUXHALL CORSA
T55OBY
Engine Mechanical problem
2003 Vauxhall Corsa 4 cyl Front Wheel Drive Manual 53OOO miles
I was wondering really what can be done about a car that burns oil like there is no tomorrow and what reasons there are for it? thanks
May 17, 2010 at 6:37 AM
DAVE H
  • 13,384 POSTS
have a compression test carried out ... possible worn valve seals .. valves .. piston rings ?
May 24, 2010 at 12:39 AM
BARRY 1
cud be a number of things why a car burns oil , cud be a sensor gon bad , messin up the fuel mix , or worse case valve stems or piston rings
May 27, 2010 at 12:15 AM
