2003 Vauxhall Corsa clutch
100,000 MILES • 4 CYL • 2WD • MANUAL
MYOLDMANSADUSTMAN
is the clutch cable or not.cannot get into gear.clutch pedal seemed to pop and now cannot use
Mar 12, 2010 at 9:00 PM
DAVE H
  • 13,383 POSTS
check the clutch cable at both ends for breaks .. pull on ends to see if the cable comes out in you hand .. it could be the clutch has gone bad .. the bearing could have popped through the springs !!
Mar 13, 2010 at 10:40 PM
