2002 Vauxhall Corsa MIDDLE EXHAUST
2002 VAUXHALL CORSA
OCONNORANDREW
Noises problem
2002 Vauxhall Corsa Front Wheel Drive Manual 60000 miles
JUST HAD M.O.T AND BEEN TOLD THE MIDDLE OF EXHAUST IS LEAKING.WHAT IS THIS?I ALSO NEED AN OFFSIDE COIL FRONT SPRING.WHAT IS THIS?
Jun 23, 2009 at 12:05 AM
  • 31,937 POSTS
HI there,
i presume that they are referring to the muffler between the cat converter and a rear muffler or resonator, the spring is the drivers side front spring, check with the inspector if you have any doubts, some country's refer to many automotive terms differently, so double check just to make sure.
Mark (mhpautos)
Jun 23, 2009 at 1:18 AM
