2002 Vauxhall Corsa heater fans have cut out
2002 VAUXHALL CORSA
NEWMARCH
Heater problem
2002 Vauxhall Corsa Two Wheel Drive Manual
the heater fans on my 02 corsa(1.7d) have stopped working. the fans then started to work again a few days later when i tried to change the speed of the blowers as were on number four the fans cut out completely, since this happened i have tried the blowers on all the speed and they do not fuction at all now. I have checked the fuses, but no fuses have been blown, when driving at speed there is still heat coming through the vents but the fans do not work.
any help anyone can give me to shed some light on my problem would be much appreicated.
thanks
p.s . could this be a case of a loose connection at the heater control panel ??
Jan 16, 2010 at 2:28 AM
DAVE H
  • 13,384 POSTS
replace the resistor located on the heater blower housing .. if the problem still persists check/replace the blower motor
Jan 16, 2010 at 7:04 PM
