2000 Vauxhall Corsa OIL LIGHT and CLUTCH.
2000 VAUXHALL CORSA
40,000 MILES • 4 CYL • 2WD • MANUAL
MARCBUNDY
Hi. The oil light keeps coming on, usually when i brake or turn the wheel. checked the oil but thats about as far as my knowledge goes on the matter. also got a new clutch put in about a month ago and theres not much bite already, have i been robbed. thanks for any info.
Dec 17, 2009 at 9:35 PM
  • 31,937 POSTS
Hi there,
This oil problem sound like oil surge, i would like to see the pressure checked with a mechanical gauge while driving if possible as this will give us a better indication as to what is happening, as for the clutch, i have no information on it in my data base, i can only suggest to see if it has any adjustment, and if it is not an adjustment problem check that the hydraulics are all ok.
mark (mhpautos)
Dec 18, 2009 at 12:28 AM
