2000 Vauxhall Corsa engine shudders
82,673 MILES • 4 CYL • 2WD • MANUAL
CHARLIE556
hi when i get up to between 30-40 mph and change into fourth gear the enigine begins to shudder and really struggles to keep the speed or gain speed as this happens the enigine malfuction light flicks on and stays on for few seconds and goes off i know i am not changing gear too soon and that there is a fault could you please help on what it could be and the price i would be looking at thanks charlie
May 24, 2009 at 1:44 AM
DAVE H
  • 13,383 POSTS
there could be numerous reason's for the symptom's your experiencing .. you need to have the vehicle plugged into a diagnostic computer to locate the cause of the CEL (check engine light) coming on and what is causing the bad response !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_733.png
May 25, 2009 at 10:39 PM
