2000 Vauxhall Corsa Diagnostic Light
BISCIT7
Electrical problem
2000 Vauxhall Corsa 4 cyl Two Wheel Drive Manual 50.000 miles
Hi there i have a problem with my corsa when the Engines cold it runs great as soon as the Engine reaches its running temp Approx 90 i take my foot off the power to slow down the Diagnostic light comes on as soon as i stop the light goes out it only does this when the Engine is hot i can also turn on the Heater to get rid of some hot Air and that stops the light coming on can you Help
Thanks ian
Feb 20, 2010 at 2:16 AM
DAVE H
  • 13,383 POSTS
replace the thermostat .. check the coolant is at correct level .. check oil level is correct ...sounds like the car is overheating
Feb 21, 2010 at 9:23 PM
