1999 Vauxhall Corsa speedometer
EVAGREY
Other Category problem
1999 Vauxhall Corsa Engine Size unknown Wheel Drive Type unknown Manual 55000 miles
My speedometer and milage has suddenly stopped working. I had a new exhaust put on a few days prior. How do i fix it and could the replacement exhuast have dislodged something
Dec 21, 2007 at 1:44 AM
ASHLEYGTIR
  • 8 POSTS
if you have a cable driven speedo then the cable could be broke, quite common, or if its fly by wire the its possible the connecter has be disturbed during the exhuast job, is the eml on or car stalling at junctions?
Dec 23, 2007 at 5:24 PM
EVAGREY
Hi no my car isn't stalling at junctions and my eml light isn't on?
Is this an expensive job to fix
Dec 23, 2007 at 10:25 PM
ASHLEYGTIR
  • 8 POSTS
1st you need to check if it cable driven or fly by wire, if its cable then youll need to get a new cable and a new speedo drive as the plastic end tends to break up, if its fly by wire then check connector on box, then check fuses as it is fused, hope this helps
Dec 26, 2007 at 2:18 AM
B0GGERS
i have the same car, and just and an exhaust job done on it about 2 weeks ago, and have the same problem. How hard is it to fix?
Jan 1, 2008 at 10:33 AM
ASHLEYGTIR
  • 8 POSTS
its not to bad to do, if its a cable then the clocks will have to come out.
Jan 3, 2008 at 4:33 AM
