1998 Vauxhall Corsa overheating?
1998 VAUXHALL CORSA
74,000 MILES • 4 CYL • 2WD • MANUAL
SUBMARINE
i havent been driving long. ive had the car 5 months or so, today i noticed the gauge on the bottom left hand of the dashboard which shows a temperture, im guessing engine temp? it was raising to 100 degrees c and raising when engine running. this is worrying. what is the problem and what do i need to do?
May 21, 2009 at 10:38 AM
DAVE H
  • 13,384 POSTS
first check the coolant level .. if this is ok .. have a repair centre inspect the coolant system with a pressure test and a cylnder compression test hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_719.png
May 21, 2009 at 10:36 PM
