1998 Vauxhall Corsa
SIMMONS7
  • 1998 VAUXHALL CORSA
  • 4 CYL
  • MANUAL
  • 107,000 MILES
I have been experienceing some trouble with my car I am driving alone then without warning the engines cuts out and then I have to turn it off and turn it on again before I can get going again I would like to know what you think about it
Wednesday, March 4th, 2009 AT 10:21 AM
DAVE H
  • 13,383 POSTS
Does the CEL/MIL (malfunction indicator light) show on the dash display? Is it on constantly?. If it is have the vehicle diagnosed by a diagnostic computer at a repair centre. In the meantime check/clean or replace the CKP (crankshaft position sensor).
Wednesday, March 4th, 2009 AT 10:33 AM
SIMMONS7
But I don't know where the sensor is and most of the light on the dashboard have not work since I have has the car or they just aint on gone
Monday, March 9th, 2009 AT 1:02 PM
DAVE H
  • 13,383 POSTS
The sensor is on the back of the engine block near the flywheel ... I suggest you go to your local library they should have a manual for the vehicle you can borrow ... with instructions on how to replce the sensor .. and how to replace the bulbs in you dash panel !! it's an easy bolt off-bolt on repalcement ... hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_112.png
Monday, March 9th, 2009 AT 2:55 PM
