1998 Vauxhall Corsa cant use my car for more than 5 mins ?
1998 VAUXHALL CORSA
BARRY 1
Engine Mechanical problem
1998 Vauxhall Corsa 4 cyl Two Wheel Drive Manual 80.000 miles
hi im going crazy with a serius problem with my car .i have a corsa 1.6 16v sport r reg 1998 . my timing belt snaped on the moter way . so i had the head referbed £660 , he rang to say done pick up , wen i got near home about 16 miles away the car staled restarted but with a slight missfire , ever since its been getting alot worse . now thers blueish smoke from the exhoust alot . with mega loads of black sut in the tail pipe , also the plugs r getting full of black sut very quickly after about 2 go,s of 5 min run , the car only runs for bout 5 mins then stalles at lights will restart but i have to rev or it will stall again there is a very bad missfire after the 5 mins at lo throtle and the car sounds like a tank loss ov about 30% power too , ive changed map sensor thermostat sensor new plugs new ht leads its fine for the first 5 mins then prety much undriveable . i had a conpreshion test dun he said it wer fine but i wernt there wen he did it ? please please help ive only just bought the car had it 10 mins wen the belt snaped . and we have no money for a new 1 , thankyou , barry
May 27, 2010 at 12:01 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation, i would be getting the mechanic to re check that the valve timing is set correctly, check for any unresolved fault codes in the ecu as well, you don't get a check light with all codes, start here and report your findings.
mark (mhpautos)
May 27, 2010 at 12:27 PM
