car starts but then cuts out?
1997 VAUXHALL CORSA
64,743 MILES • 4 CYL • 2WD • MANUAL
DECIBELS1
i have 2 keys for my vauxhall corsa trip and each key does different things to the engine light 1 key makes it flash the other key makes the engine light stay on. the car starts but then cuts out and occasionally shakes iv removed the fuse for anti theft protection and alarm and rear window heater also tried the de-activation sequence for immobiliser with the key start ignition?
Mar 25, 2010 at 7:52 AM
  • CAR REPAIR CONTRIBUTOR
Unfortunately we don't have a manual on this vehicle but this is a theft system issue.
We need to start with checking the codes and finding out what is there because this normally puts a couple codes in the PCM to tell us what is happening.
Then we are going to have to try some of the GM tactics to disarm the system starting with putting the key in the ignition in the on position for up to 30 minutes to see if it turns the system off.
https://www.2carpros.com/articles/how-to-reset-a-security-system
If this doesn't work then we will most likely need to contact a dealer to see what they say about how to disable this system.
Please run through this info and let us know what you find. Thanks
Sep 24, 2021 at 4:38 PM
