HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Vauxhall
Corsa
Engine
Starter
Replace/Remove
1990 Vauxhall Corsa change starter motor
HARPER
MEMBER
1990 VAUXHALL CORSA
4 CYL
2WD
MANUAL
102,000 MILES
Removing faulty starter motor having difficulty undoing second retaining bolt
Thursday, December 27th, 2007 AT 1:58 PM
ASHLEYGTIR
MEMBER
Would that be the one on the top of the starter? 13mm?
Thursday, January 3rd, 2008 AT 12:39 PM
Please
login
or
register
to post a reply.
Related Starter Replace/Remove Content
1996 Vauxhall Corsa Replaced Stater, Now Just...
Transmission Problem 1996 Vauxhall Corsa Two Wheel Drive Manual Hi There, I Am Very Amatuer At Mechanics, However. I Have Just...
Asked by
partonbill
1 ANSWER
1996
VAUXHALL CORSA
VIDEO
Starter Replacement
Instructional repair video
GUIDE
Starter Motor Replacement
A starter motor is a high torque motor that utilizes a small pinion gear to contact the flywheel and a starter solenoid to initiate the electrical connection when the...
2003 Vauxhall Corsa Starter Motor
Hello, My Name Is Pete, I Am Changing The Starter Motor On A Corsa Dti, It Is Very Buried At The Back Of The Engine, Do I Go From The...
Asked by
ptr685
2003
VAUXHALL CORSA
2001 Vauxhall Corsa Starter
I Own A Corsa Diesel Intermitantley When I Turn The Ignition Key There Is No Responce Battery Replaced Told There Is A Starter Relay...
Asked by
tom morris
1 ANSWER
2001
VAUXHALL CORSA
2005 Vauxhall Corsa Fitting Mass Air Flowmeter
Engine Mechanical Problem 2005 Vauxhall Corsa Two Wheel Drive Manual 32000 Miles I Have My Engine Management Light Coming On And Have...
Asked by
barefoot singer
2005
VAUXHALL CORSA
2002 Vauxhall Corsa Engine Number
Warranty Problem 52 Plate Vauxhall Corsa 4 Cyl Two Wheel Drive Manual 85000 Miles Hi Ive Got A Vauxhall Corsa & I Want To Know Where...
Asked by
alanm2007
1 ANSWER
2002
VAUXHALL CORSA
VIEW MORE
Starter Replacement
Starter Replacement
