1989 Vauxhall Corsa
97,000 MILES • 4 CYL • 2WD • MANUAL
STUART MC LEOD
1 bent valve new cylender head gasket new valve this has now been fixed problem now is when u start car all is fine untill car has had about 5 mins heat in it
then the oil light comes on and there is a noise coming from the rocker cover area it is a ticking noise which get louder and louder . when this car was fixed took it for a test drive all ok 10 miles in to test drive oil light came on and the ticking noise started
got back to base checked oil, oil ok let the car cool down them started the car up again no noise untill it heat up again and noise started agian ticking noise coming from rocker cover area any help please
Apr 4, 2009 at 9:28 AM
DAVE H
  • 13,383 POSTS
sounds like you may have a blocked/restricted oil supply line ? is the headgasket on correctly ? is it the correct gasket ?
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_434.png
Apr 5, 2009 at 12:19 AM
