2005 Vauxhall Combo Non Starter
BILLYWIZZ84
Engine Mechanical problem
2005 Vauxhall Combo 4 cyl Two Wheel Drive Manual
VAUXHALL COMBO 1.3 CDTI 16V DIESEL, timing tenchioner har broke. part replaced, timing set but van will not start. Engine turns but wont fire up.
Any idea
May 19, 2009 at 8:42 AM
DAVE H
  • 13,383 POSTS
did you check for bent valves ... I suspect you have bent some valves when the belt broke !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_708.png
May 19, 2009 at 10:12 PM
