1997 Vauxhall Cavalier Ignition failure/ starter motor
1997 VAUXHALL CAVALIER
DONKONE
Electrical problem
1997 Vauxhall Cavalier 6 cyl Front Wheel Drive Manual 90.000 miles
When ignition is turned on to start engine, starter motor turns slowly, failing to start engine. Why is this happening?
Apr 13, 2009 at 3:01 AM
DAVE H
  • 13,384 POSTS
check battery for correct 12.5 volts ... check starter motor wiring is not corroded or worn away .. and lastly check or replace the starter motor !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_489.png
Apr 14, 2009 at 9:45 PM
