1995 Vauxhall Cavalier ignition switch
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
BEANER1952
how do i remove the switch
Feb 27, 2009 at 8:08 AM
DAVE H
  • 13,383 POSTS
the switch is a simple repair .. remove the cover around the steering column .. at the back of the key barrel .. you will see the a round black plastic piece with wires connected .. take the screw out of this and unclip it from the barrel housing ... unclip the wiring connector from wiring loom and replace with new switch in reverse order
Feb 27, 2009 at 11:24 AM
