2007 Vauxhall Astra DASHBOARD WARNING LIGHT
44,000 MILES • 4 CYL • 2WD • MANUAL
JOHNSW1
I HAVE RECENTLY HAD NEW IGNITION COIL AND PLUGS FITTED BUT NOW HAVE LIGHT ON DASHBOARD ITS A PICTURE OF A CAR WITH A SPANNER IN IT CAN YOU EXPLAIN THIS PLEASE
May 10, 2009 at 7:53 AM
DAVE H
  • 13,383 POSTS
have the vehicle plugged into a diagnostic computer to locate the cause of the fault ... the light is telling you there is an electrical fault .. it could be due to the coil/plugs change and the light just needs turning off by the computer !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_683.png
May 10, 2009 at 10:14 PM
