2006 Vauxhall Astra
2006 VAUXHALL ASTRA
RUTLANDRAGTOPS
Electrical problem
2006 Vauxhall Astra 4 cyl Front Wheel Drive Manual
I purchased an OBD2 u380 code reader. When I plug it in it powers up but then comes up with 'Linking Error' It says in the manual that it may be unable to communicate with the car.What can I do? am I using the wrong scanner? The car is a 2006 1.9 turbo Diesel Vauxhall Astra Twintop.
Apr 21, 2009 at 9:09 AM
DAVE H
  • 13,384 POSTS
The scanner should actually work on your vehicle ... some of the older model scanners do not work on deisel engines .. try linking it to a friends vehicle to be sure the scanner is working correctly !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_556.png
Apr 22, 2009 at 6:04 AM
