2005 Vauxhall Astra REAR WINDSCREEN WASHERS
50,000 MILES • 4 CYL • FWD • MANUAL
GAZZ
MY REAR WINDSCREEN WASHER IS NOT WORKING BUT THE MOTOR STILL MAKES A NOISE WHEN I PULL LEVER ,I THINK IT MAY BE BLOCKED SOMEWHERE . I UNDERSTAND THERE IS A FILTER SOMEWHERE BUT WHERE AND HOW DO I CLEAN IT OUT.
Apr 7, 2009 at 8:03 PM
DAVE H
  • 13,383 POSTS
The filter is located on the pump motor water inlet ..pull the pump out of the filler bottle and you will see the filter ... also blow air through the water supply lines to the screens to clear them out !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_470.png
Apr 7, 2009 at 11:12 PM
