2004 Vauxhall Astra engine swapping
2004 VAUXHALL ASTRA
AARON1982
Engine Performance problem
2004 Vauxhall Astra 4 cyl Two Wheel Drive Manual
will a 2.5td omega engine fit straight into my astravan 1.7dti without changing the gearbox and wiring
Aug 8, 2009 at 1:38 PM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
No .. the engine mounts will be the first obstacle .. then maybe the gearbox is different depending on the year of the donor car ... then the PCM (computer) settings will all be different ... the wiring may be different ... ?? etc. etc.
Aug 9, 2009 at 6:11 PM
