2004 Vauxhall Astra car idle
GULLY
Engine Mechanical problem
2004 Vauxhall Astra 4 cyl Two Wheel Drive Manual
astra 1.6 ecotec z16xep.the car when cold idles normal until it get hot ,then the idle starts to go up & down slowly causing the car to stall.some times the car wont stall but will start to make a noise,but when i press the accelator the noise goes away,but comes back after 30 seconds.when i pull out dip stick the car is sucking in air.the car drives lovely no problem apart from the one mentioned.thanx.
Nov 2, 2008 at 6:46 AM
DAVE H
  • 13,383 POSTS
inspect vacuum hoses for kinks/splits etc.
Nov 12, 2008 at 2:10 PM
