2004 Vauxhall Astra
2004 VAUXHALL ASTRA
60,000 MILES • 4 CYL • 2WD • MANUAL
STEVEPRE
I am driving along for about 2 miles and the engine just cuts out. The car will not restart for about ten minutes. The car is not steerable so I have to hope I am near the inside lane.
May 1, 2008 at 10:42 PM
  • 31,937 POSTS
Hi there,
you should first check for any set fault codes. there may be an engine management issue and a code will help locate it. If no code, start checking for a faulty fuel pump or blocked filter, when it stops also see if it has lost spark, this will help also to diagnose the problem.
Mark (mhpautos)
May 1, 2008 at 11:02 PM
