2004 Vauxhall Astra
2004 VAUXHALL ASTRA
60,000 MILES • 4 CYL • 2WD • MANUAL
STEVEPRE
I am driving along for about 2 miles and the engine just cuts out. The car will not restart for about ten minutes. The car is not steerable so I have to hope I am near the inside lane.
May 2, 2008 at 5:42 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
you should first check for any set fault codes. there may be an engine management issue and a code will help locate it. If no code, start checking for a faulty fuel pump or blocked filter, when it stops also see if it has lost spark, this will help also to diagnose the problem.
Mark (mhpautos)
May 2, 2008 at 6:02 AM
