2003 Vauxhall Astra yellow engine light stays on
2003 VAUXHALL ASTRA
65,000 MILES • V8 • 4WD • MANUAL
SHAZZA221258
i have had the car in a garage they changed the coil block and all plugs
fault keep saying cylinder 3 misfiring when light is reset itsays no fault found
as soon as i drive it away the light comes on again and car is driving very shaky
also i noticed a lot of water is disappearing when car is in use it has to be topped up regular
i have checked for all signs of head gasket damage
the mechanic also did pressure checks on water pump head gasket and all cylinders but all showing a good pressure
i dontr want to keep going back as he seems to have no idea what it can be
please help
Nov 23, 2009 at 9:46 PM
DAVE H
  • 13,384 POSTS
replace the plug leads ... check the injector on cylinder 3 .. a bad injector will cause cylinder misfire !
Nov 24, 2009 at 10:05 AM
