Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Vauxhall
Astra
Climate Control
Heater
Not Working
2003 Vauxhall Astra no heat no cold
2003 VAUXHALL ASTRA
46,500 MILES • 4 CYL • FWD • MANUAL
ANTHONY COGGINS
MEMBER
1 POST
with the blower on full and the engine warm no heat coming from the vents . turn the heat dial to cold and the air temp stays the same.
Oct 28, 2008 at 6:01 PM
DAVE H
Experienced Mechanic
unless you have air con the blower will only blow air .. not cold air .. the heater not working is prob your thermostat stuck ..
Nov 12, 2008 at 2:21 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
