I recently purchased an OEM rubber pad to replace my worn out pad for the clutch pedal of my Astra 2003 model. However I'm having great difficulties trying to fix it to the pedal. The rubber pad is rather hard (unlike others such as Mazda's which can easily be slotted in). I've tried soaking it in a bowl of hot water for 5 minutes to soften it but still couldn't fully attach it to the pedal. At most, I could only fix the top half as I couldn't get the pedal to fully slot in the small and tight gap at the back of the rubber pad. Any tricks to this?
Jun 26, 2010 at 11:59 PM
