2003 Vauxhall Astra Car not Revving
2003 VAUXHALL ASTRA
KABZ123
Engine Performance problem
2003 Vauxhall Astra Front Wheel Drive Manual 70000 miles
When i switch on ignition car does not rev past 2000 revs. after leaving engine on for 5 - 10 mins it revs up to 2500, but basically when i drive it, i cant accelerate, it does not give gas, does not rev. I can only just about drive in 1st gear cant get past that.
Apr 14, 2010 at 10:58 PM
DAVE H
  • 13,384 POSTS
have the car plugged into a diagnostic computer to check for fault codes stored on the cars PCM (computer) .. it could be in limp mode or a throttle position sensor fault
Apr 15, 2010 at 7:51 PM
KABZ123
ok thanks will do that.
I asked few garages most saying air flow mass sensor or electrical fault, because also the exhaust back box is broken and requires a new one or either weilding.
one mechanic told me its most probably cam sensor as these are common faults in astra's and i think he is correct, it may well be that.
He told me to disconnect the air flow pipe and then start and rev car which i did, but noticed underneath air flow pipe there was a switch disconnected which i think leads to camshaft. i connected that back and started car. at first it would not start but eventually did and started revving fine but then just cut out.
so i disconnected that again and then same thing, car starts but does not rev past 2000
Apr 15, 2010 at 9:08 PM
DAVE H
  • 13,384 POSTS
I need to know the fault codes from the vehicle ! .. we could be replacing parts without reason and at great expense before stumbling on the cause of the fault ! .. there are a lot of reasons the car will go into limp mode .. the codes will pinpoint the cause !!
Apr 16, 2010 at 8:08 PM
