HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Vauxhall
Astra
Interior
Instrument Cluster
Gauges
Speedometer
Not Working
2003 Vauxhall Astra
ROBERT BAYLISS
MEMBER
2003 VAUXHALL ASTRA
Engine Performance problem
2003 Vauxhall Astra 4 cyl Front Wheel Drive Manual 140.00 miles
could someone plese tell me what sort of price I would be looking if I got valve fix and engine stalls when clutch. And speedo does not work
Tuesday, September 2nd, 2008 AT 1:12 PM
ROBERT BAYLISS
MEMBER
Tuesday, September 2nd, 2008 AT 1:14 PM
Please
login
or
register
to post a reply.
Related Instrument Cluster Gauge Speedometer Not Working Content
2002 Vauxhall Astra Speedo
2002 Vauxhall Astra V8 Two Wheel Drive Automatic Hi My Speedo Is Not Working And Its Somethin To Do This Sensor On The Hub I Havent Got...
Asked by
terena
2002
VAUXHALL ASTRA
2001 Vauxhall Astra Indicator Light On Speedo
2001 Vauxhall Astra 6 Cyl Manual 112000 Miles I Have A Light Up On My Speedo, That Is Like A Hose Type Shape. ( As You Can Guess By...
Asked by
sarahxo
1 ANSWER
2001
VAUXHALL ASTRA
1999 Vauxhall Astra Fan Not Cutting In
The Engine Fan Is Not Cutting In And Allowing The Temperature Gauge To Go Into The Red I Have Checked The Fan Direct From The Battery And...
Asked by
brisan559
1 ANSWER
1999
VAUXHALL ASTRA
2003 Vauxhall Astra Water Flow
Just Got 53 Reg Astra And Have Noticed That Even On Startup The Water Flows From Some Unit Top Of Engine To The Water Tank, No Sign Of Loss...
Asked by
Perrin
1 ANSWER
2003
VAUXHALL ASTRA
2004 Vauxhall Astra Leak Behind Driver's Seat
Hi There My Astra Has A Leak And Is Very Wet Behind The Driver's Seat. It Happens When The Car Is Parked And There Is Heavy Rain, And...
Asked by
stmcgill
1 ANSWER
2004
VAUXHALL ASTRA
VIEW MORE
Instrument Cluster Replacement
How to Use a Test Light
Airbag Removal - Drivers Side
