2002 Vauxhall Astra speedo
2002 VAUXHALL ASTRA
TERENA
2002 Vauxhall Astra V8 Two Wheel Drive Automatic
hi my speedo is not working and its somethin to do this sensor on the hub i havent got it fixed coz i dont no what this part is called can you help
Jun 24, 2010 at 8:59 AM
DAVE H
  • 13,384 POSTS
Vehicle speed sensor (VSS) is usually located on the transmission .. there is sesnors on the wheels (wheel speed sensors) used for the ABS ?
Jun 26, 2010 at 8:56 PM
TERENA
the car havent got abs, and because of this sensor its teling the car it shouldnt be running, and cuts out sometimes, s do you think if iget the vss it will stop the problem thanks
Jun 26, 2010 at 9:09 PM
DAVE H
  • 13,384 POSTS
The car may cut out because the speedo is not working, but it is not common ? the VSS tells the ECU/PCM when to shift gear and apply torque converter clutch, if the ECU/PCM is not getting correct signal you will also get harsh/late gear shift's .. did you have the vehicle plugged into a diagnostic scanner/computer to retrieve any fault codes stored ? when it cuts out, does it start again straight away ? Let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1157.png
Jun 27, 2010 at 9:06 PM
TERENA
yea the car starts straight away when it cuts out. it was my dads car he took it to vauxhall and they aid it was a wheel bearing housing? never heard of this! im tryin to find one of them vss but cant find one at the moment u no where i can get one from im in newport south wales? just i cant afford to take my car to a garage thanks
Jun 28, 2010 at 7:45 PM
