2002 Vauxhall Astra speedo
TERENA
2002 Vauxhall Astra V8 Two Wheel Drive Automatic
hi my speedo is not working and its somethin to do this sensor on the hub i havent got it fixed coz i dont no what this part is called can you help
Jun 24, 2010 at 8:59 AM
DAVE H
  • 13,383 POSTS
Vehicle speed sensor (VSS) is usually located on the transmission .. there is sesnors on the wheels (wheel speed sensors) used for the ABS ?
Jun 26, 2010 at 8:56 PM
TERENA
the car havent got abs, and because of this sensor its teling the car it shouldnt be running, and cuts out sometimes, s do you think if iget the vss it will stop the problem thanks
Jun 26, 2010 at 9:09 PM
DAVE H
  • 13,383 POSTS
The car may cut out because the speedo is not working, but it is not common ? the VSS tells the ECU/PCM when to shift gear and apply torque converter clutch, if the ECU/PCM is not getting correct signal you will also get harsh/late gear shift's .. did you have the vehicle plugged into a diagnostic scanner/computer to retrieve any fault codes stored ? when it cuts out, does it start again straight away ? Let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1157.png
Jun 27, 2010 at 9:06 PM
TERENA
yea the car starts straight away when it cuts out. it was my dads car he took it to vauxhall and they aid it was a wheel bearing housing? never heard of this! im tryin to find one of them vss but cant find one at the moment u no where i can get one from im in newport south wales? just i cant afford to take my car to a garage thanks
Jun 28, 2010 at 7:45 PM
