2002 Vauxhall Astra possible faulty clutch
48,000 MILES • 4 CYL • FWD • MANUAL
CLFSMASHER
my clutch pedal vibrates when pulling off and on occasion it judders when cold after a few gear changes it seems to be fine although the vibration is constant, ive also noticed that when left for ten mins or so the car is started and it sometimes takes a few seconds to climb to normal idle speed,when it does this i can hear a whining sound for a couple of seconds that degrades as if the starter is running on. any ideas
Aug 13, 2008 at 10:07 AM
DAVE H
  • 13,383 POSTS
check the starter motor is not sticking in engaged position .. this could explain all these symptoms !
Feb 23, 2009 at 11:33 PM
