2002 Vauxhall Astra Motar rotates fan belt of rediator maki
2002 VAUXHALL ASTRA
SHAKTI SHARAN DUBEY
Engine Performance problem
2002 Vauxhall Astra Four Wheel Drive Manual 88000 miles
Actually the motar which is connected to the fan belt
is making some noise,what might cud have happened?
And also the coolent in my car is finishing in 2 to 3 months and there is no sign of any leakage when check
in the morning everyday before starting the Engine.Please advice.Thanks
Sep 5, 2009 at 6:54 PM
DAVE H
  • 13,384 POSTS
check the belt is at the correct tension .. the bearings in the tensioner or motor could be worn .. have a compression test of the cylinders for the coolant loss !!
Sep 6, 2009 at 8:33 PM
