2002 Vauxhall Astra Fixing a rear spring
GEMGEM28
Suspension problem
2002 Vauxhall Astra 6 cyl Two Wheel Drive
How do you fix a rear spring on a 1.6 vauxhall astra?
Sep 7, 2009 at 9:14 PM
DAVE H
  • 13,383 POSTS
you need to replace the spring .. it cannot be repaired .. you need to remove the strut form the car .. remove the spring from the strut (for which you need a special tool).. then replace in reverse order !!
Sep 7, 2009 at 9:22 PM
GEMGEM28
right ok then thanks. What happens if i want to replace the back spring in a vauxhall astra? What is the process which I need to go through?
Sep 7, 2009 at 10:28 PM
DAVE H
  • 13,383 POSTS
remove the strut & spring from the car as a unit, they are joined together
apply the spring compressor tool to the spring
compress the spring
undo the top bolt holding the spring onto the strut
remove the spring from strut .. Be very carefull this spring is compressed and if not done correctly can cause serious injury ...
remove spring compressor from old spring and compress new spring
replace in reverse order ..
*****this can be a very dangerous repair if not carried out correctly*****
Sep 7, 2009 at 10:56 PM
