2002 Vauxhall Astra engine cuts out while slowing down at j
80,000 MILES • 4 CYL • 2WD • MANUAL
ASTRA 02
hi just had a new radiator fitted. since then when i slow down to approach a junction the engine cuts out and all warning lights come on, like engine has been turned off. had an oil change, chasnged fuell pump relay switch but not sure which switch is correct one, changed nearest one, could it be fuell fillter? or what else? diagnosis machine showed no faults.
Dec 22, 2008 at 1:38 AM
DAVE H
  • 13,383 POSTS
add a good fuel injector cleaner ..
Jan 31, 2009 at 2:01 PM
