2002 Vauxhall Astra Broken rear spring
65,000 MILES • 4 CYL • 2WD • MANUAL
EASTMAN42
Bottom coil on rear spring has broken. This is a common problem on vauhalls, i am told. There doesn't appear to be much involved with changing this? Is it as straightforward as it looks? I assume i wil need spring compressors? Thanks
Nov 1, 2009 at 7:34 PM
DAVE H
  • 13,383 POSTS
yes you need a spring compressor ... it is a straightforward repair if you have a little experience !
Nov 1, 2009 at 8:24 PM
