HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Vauxhall
Astra
Drivetrain
Transfer Case
Replace/Remove
2002 Vauxhall Astra
LITTLE.DAVE
MEMBER
2002 VAUXHALL ASTRA
Engine Mechanical problem
2002 Vauxhall Astra 4 cyl Two Wheel Drive Manual 108.00 miles
i have a 52 plate astra sxi its starts put got no power to pull away its had a av vavle replaced could give any surgestions on what it could be
Saturday, November 28th, 2009 AT 3:19 AM
DAVE H
MECHANIC
If the vehicle is not moving at all. The clutch is probably slipping !
Saturday, November 28th, 2009 AT 7:03 AM
LITTLE.DAVE
MEMBER
The car moves when u take the revers upto 5,000 revs
Saturday, November 28th, 2009 AT 11:25 AM
DAVE H
MECHANIC
Definately sounds like your clutch is slipping and needs replacing !!
Saturday, November 28th, 2009 AT 3:52 PM
Please
login
or
register
to post a reply.
Related Transfer Case Replace/Remove Content
Replace Front Springs
How Do I Change A Front Springs?
Asked by
sparky1908
1 ANSWER
2003
VAUXHALL ASTRA
1996 Vauxhall Astra
Electrical Problem 1996 Vauxhall Astra 4 Cyl Two Wheel Drive Manual How To Reaset Ermoberlizer After Changingbattery
Asked by
andrew randall
1 ANSWER
1996
VAUXHALL ASTRA
1998 Vauxhall Astra
Electrical Problem 1998 Vauxhall Astra 4 Cyl Two Wheel Drive Manual My Car Has Immobilized Itself How Do I Fix This.
Asked by
ufcbazz84
1 ANSWER
1998
VAUXHALL ASTRA
2001 Vauxhall Astra
Engine Performance Problem 2001 Vauxhall Astra 4 Cyl Front Wheel Drive Manual 87.000 Miles Droped Performace But Still Runs Sound Bad...
Asked by
carrieann88
1 ANSWER
2001
VAUXHALL ASTRA
1999 Vauxhall Astra
Engine Mechanical Problem 1999 Vauxhall Astra 4 Cyl Front Wheel Drive Manual The Car Gets To 4500 Rpm Then Holds Back
Asked by
paul_1975
1 ANSWER
1999
VAUXHALL ASTRA
VIEW MORE
Driveshaft Removal
Transmission Service Ford F-150 2011-2014
Automatic Transmission Replacement
