2001 Vauxhall Astra oil cap
2001 VAUXHALL ASTRA
MICK987
Engine problem
2001 Vauxhall Astra Engine Size unknown Front Wheel Drive Manual 58000 miles
the inside of my oil cap is milky white. can you tell me what the problem is please?
Jan 19, 2008 at 5:19 AM
  • 31,937 POSTS
Hi there,
If this is the only emulsified oil visible, don't worry to much. this is condensation that has not evaporated away due to prolonged low engine temp. If the engine does not reach operating temp on a regular basis, you get this condensation building up and causing the milky oil. Check for coolant loss to be on the safe side, but if you only do short runs, you will get this happening. Ask you mechanic to flush the system out, and try to get a few longer runs in, your exhaust system will benefit as well.
Mark (mhpautos)
Jan 19, 2008 at 12:30 PM
