2001 Vauxhall Astra ENGINE CONTROL INDICATOR
VSSNAGA
Computer problem
2001 Vauxhall Astra Engine Size unknown Front Wheel Drive Automatic 70000 miles
MY ENGINE CONTROL INDICATOR LIGHT IS ON FOR MY ASTRA.SHOWING CAR AND THE SPANNER ON MY SPEEDO.WHAT DOES THIS MEAN? HOW MUCH DOESIT COST TO FIX IT?
Jan 31, 2008 at 10:48 AM
EXETERGUY
i had this problem with my vectra, the engine management has discovered a possible fault, you will also have lost power, the vehicle needs testing and connecting to a device called a tech2, and vauxhall will charge £70 just tio connect this machine and tell you what the fault is, then charge you more to repair the fault!
May 3, 2008 at 4:00 AM
CLFSMASHER
the light with the car and spanner is a service light and providing you have serviced it recently you can turn it off by turning on ignition lights only then press the brake and press and hold the reset button on the dials until the light goes out.turn off ign and turn back on.
Aug 13, 2008 at 10:25 AM
