2001 Vauxhall Astra cutting out
2001 VAUXHALL ASTRA
112,000 MILES • 4 CYL • FWD • MANUAL
MARKSHEPSTONE
hi there, was wondering if anyone has heard of this problem before, i have a vauxhall astra 1.6 sxi 16v, and all of a sudden it has been cutting out on the bypass or motorway, if i am driving at a constant speed on the bypass, i.e. 60mph the car judders then cuts out and wont start by the the key, it has to be bump started.
i dont even know where to start with it,
the car has just had a major service 3000 miles ago, including timing belt,
iv checked for fault codes and there are none,
i have also blocked off the egr valve with the modified gasket from vauxhall.
i dont understand what os happening, and would appriciate some help.
thanks you
mark :)
Nov 2, 2009 at 8:04 AM
DAVE H
  • 13,384 POSTS
start by testing the battery and alternator are good and also replace the CKP (crankshaft position) sensor
Nov 3, 2009 at 5:19 PM
MARKSHEPSTONE
the ttery is brand new, and the charging voltage is sitting around 14 volts. il try the cpk sensor and let you know how i get on
cheers
Nov 4, 2009 at 4:55 AM
