2000 Vauxhall Astra windows,wing mirrors
111,000 MILES • 4 CYL • 2WD • MANUAL
ROYLES
electric front windows and electric mirrors on both sides have stopped working,also window switches fail to light up when headlamps are switched on.have checked fuses on the dropdown fusepanel to the right of the steering column and they appear to be fine,should i be looking for a relay,your help would be most appreciated,thanks.
Oct 23, 2009 at 11:27 PM
DAVE H
  • 13,383 POSTS
sounds like you have no power going to the main switch on the drivers door ... I would double check all fuse's including under the bonnet/hood .. if these are all OK .... you will have to check you are getting a live/hot feed to the switch !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_110.png
Oct 24, 2009 at 9:16 PM
