2000 Vauxhall Astra starter motor
165,000 MILES • 6 CYL • 2WD • MANUAL
JAMIEPARR1981
please can you help i have replaced the the starter motor 3 times all brand new and it has failed again. the manufactures say that the starters are over running.
Nov 20, 2008 at 8:06 PM
DAVE H
  • 13,383 POSTS
the only way your starter is over running is if your keepig the key turned for too long or your starter switch to starter wiring is wrong and you would here the noise of this when starting vehicle ... i would get a OEM part from vauxhall and try this .. if this works good .. then claim your money back from manufacturers of bad starters ..
Nov 20, 2008 at 8:41 PM
