2000 Vauxhall Astra sqeaking and howling noises
MARK LINDLEY
Brakes problem
2000 Vauxhall Astra Engine Size unknown Four Wheel Drive Manual 125000 miles
it happens at random times. a whistling noise starts like a bird flying along with you whilst driving then a high pitched howling noise starts. will be worse when going slower. sometimes worse when i turn the wheel right then stops when turning left. The noise STOPS usually when i press the break. These are new brakes pads and discs fitted 1000 miles ago although has made these noises since new,. there is no pattern...sometimes will have been driving a few miles then it starts and will last remainder of journey. sometimes straight from moving off. other times it only lasts a couple of minutes.sometimes drive to work its fine then drive home and it starts...Can you help
Feb 2, 2008 at 8:35 PM
DAVE H
  • 13,383 POSTS
have the brakes reinspected and ask them to check the wheel bearings as well
Feb 23, 2009 at 8:34 PM
