2000 Vauxhall Astra sqeaking and howling noises
2000 VAUXHALL ASTRA
MARK LINDLEY
Brakes problem
2000 Vauxhall Astra Engine Size unknown Four Wheel Drive Manual 125000 miles
it happens at random times. a whistling noise starts like a bird flying along with you whilst driving then a high pitched howling noise starts. will be worse when going slower. sometimes worse when i turn the wheel right then stops when turning left. The noise STOPS usually when i press the break. These are new brakes pads and discs fitted 1000 miles ago although has made these noises since new,. there is no pattern...sometimes will have been driving a few miles then it starts and will last remainder of journey. sometimes straight from moving off. other times it only lasts a couple of minutes.sometimes drive to work its fine then drive home and it starts...Can you help
Feb 2, 2008 at 8:35 PM
DAVE H
  • 13,384 POSTS
have the brakes reinspected and ask them to check the wheel bearings as well
Feb 23, 2009 at 8:34 PM
