2000 Vauxhall Astra No Drive
2000 VAUXHALL ASTRA
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
NORRIS1968
Hi The engine runs fine and starts well,but when i select Drive or reverse or 123 gears on the automatic gearbox nothing happens. I have no drive what could this be. Thanks
May 16, 2009 at 11:23 AM
DAVE H
  • 13,384 POSTS
you could have a bad torque convertor ... or a fault on the transimission control system .. you need to have a repair centre check this out for you !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_711.png
May 19, 2009 at 10:25 PM
