2000 Vauxhall Astra alternator
114,000 MILES • 4 CYL • 2WD • MANUAL
MACHINIST50
hi the alternator bearing is starting to go without taking it out how can i tell what make it is, should i go for a secondhand one, anyway of getting a cheaper one than vauxhalls,are there any copies out there that i should adviod if so how do i tell the difference, is repairing it an option.
regards tom
Jul 30, 2009 at 5:42 AM
DAVE H
  • 13,383 POSTS
most good autoparts stores will be able to tell you the make and model of the alternator fitted ... I would never use a secondhand (used) unit ...the best replacement would be an OEM (dealer) unit .. your cheapest option would be to have yours reconditioned ...
Jul 31, 2009 at 9:03 PM
