1999 Vauxhall Astra Fuel Pump reset switch
1999 VAUXHALL ASTRA
77,850 MILES • 6 CYL • 2WD • MANUAL
JAMCEFIELD
Hi my astra is a 1.6 8v. after loading the car my car has failed to start, after looking around i found that the fuel pump is not working it just seems to have stopped dead there is no buss when i put the ignition on.
i was just wondering if there is a reset switch and if so where abouts on the car is it located
any help would be most welcome
Jul 11, 2009 at 11:49 PM
SLURPY
I can't give a difinitive answer but if it's any help you could first try checking the pump relay fuse. It is located in the engine compartment inside the relay/fuse box and should be purple. The cost of a replacement is approx. 10GBP.
Jul 14, 2009 at 1:01 AM
DAVE H
  • 13,384 POSTS
check/replace the fuse and relay ... then check you are getting power at the pump to check the wiring is good .. if yes to power ... replace the pump
hope this helps
Dave H
Jul 14, 2009 at 11:57 AM
